Re: AR-15 build thread. What parts and tools do U use?
[Re: gun dog]
#1004992
06/14/14 02:08 PM
gun dog
Posts: 12,736 |
Thank for the link. The list will be most useful do to the fact I can't watch videos on my current internet. I believe assembly will not be an issue once I have the right tools. I'm learning. But have some mechanical aptitude.
[Re: gun dog]
#1004994
06/14/14 04:05 PM
Ray Settanta
Posts: 19,616 |
If you can't watch vids, here is a good tutorial with text and drawings for the lower receiver. http://www.ar15.com/content/guides/assembly/lower/There is also a short list of tools and how to tell which spring is which. This helped me a lot the first time.
JYD #182
[Re: gun dog]
#1004998
06/14/14 05:11 PM
gun dog
Posts: 12,736 |
Cool. Hopefully being a machinest I will already have some of what I need
[Re: gun dog]
#1005002
06/14/14 06:52 PM
Ray Settanta
Posts: 19,616 |
You will also need a 1/2" drive torque wrench and a wrench for the barrel nut. If you are going to use a free-float hand guard, some times the manufacturer includes a wrench for their barrel nut.
JYD #182
[Re: gun dog]
#1005004
06/14/14 06:59 PM
Ray Settanta
Posts: 19,616 |
Some of the tools, such as, the Ejector Removal Tool, Hammer Drop Block and the Pivot Pin Installation Tool are not strictly necessary but make things easier.
JYD #182
[Re: gun dog]
#1005006
06/14/14 11:46 PM
gun dog
Posts: 12,736 |
Ok this seems it will be a long list.
[Re: gun dog]
#1005045
06/15/14 12:06 PM
Spider-Pig
Posts: 4,857 |
Mike, if you're concerned with cost then you should know that you will be spending more money building an AR than you would be buying a complete one. It used to be the other way around but not anymore. I would just try and find something that comes as close as possible to meeting your requirements, then changing whatever it is that will make it exactly what you want.
"Be still, Taggart!"
[Re: gun dog]
#1005046
06/15/14 12:14 PM
Spider-Pig
Posts: 4,857 |
I bought a complete upper assembly minus the bcg and rear sight, a complete lower assembly, a bcg, and a rear sight. All that gave me a complete rifle. I changed the six position stock to a fixed stock, changed the pg, and slightly upgraded the trigger, and now I have the exact rifle I want. I would've spent more money doing a complete build, but I would've spent less if I would've bought a complete rifle then changed the parts.
[Re: gun dog]
#1005048
06/15/14 12:47 PM
gun dog
Posts: 12,736 |
^^^ while I so want a good deal I want to also have experince. Maybe I need to start like you suggested. My ffl can get a spikes complet lower with m4 stick for $270
[Re: Spider-Pig]
#1005052
06/15/14 03:54 PM
greaser
Posts: 7,098 |
Mike, if you're concerned with cost then you should know that you will be spending more money building an AR than you would be buying a complete one. It used to be the other way around but not anymore. I would just try and find something that comes as close as possible to meeting your requirements, then changing whatever it is that will make it exactly what you want. I think this is true and it isn't. Yes you can buy a base bottom barrel AR cheaper than you can build one but you can build a mid grade and up AR for much less than you can buy one and if you take your time and are careful you will only have to spend the money once because it will be the way you want it from the start. Not trying to call you out Spidy as I am sure you know this just putting it out there for anyone who doesn't know.
JYD#176 "dein Gott schickte mich zu zerstören" "Sic semper evello mortem Tyrannis" "Sometimes the chance of a zombie outbreak is the only reason I need to make many of my life's Decisions." General Delivery
[Re: gun dog]
#1005053
06/15/14 03:58 PM
Spider-Pig
Posts: 4,857 |
Well, I will agree with you if you're replacing major components like a barrel. If you're replacing a barrel or something similar in price then I would say you're nowhere near being close to exactly what you want. I'm talking furniture and other less costly components.
[Re: gun dog]
#1005055
06/15/14 04:47 PM
Ray Settanta
Posts: 19,616 |
I built one just for the experience. I kept track of the parts cost and some day I will add it all up to see what it cost me. I do know it was fun and a great experience. And since I am a tool junkie. I also bought all the specialized tools for the next build. That did make the build easier but they were not completely necessary. I learned a lot that I would not have if I bought a complete rifle.
JYD #182
