Re: Personal Survival Kit (Minimum Gear 4 Max Effect)
#1038365
02/27/16 08:24 AM
Posts: 117,050 |
I may be anal retentive on this but a couple questions about items on your list.
1. Why a bic lighter instead of one of the Peanut XL lighters from County Comm? They will hold a lot of easily obtained conventional zippo lighter fluid plus they seal up with O rings and shouldn't leak out any of the fluid. 2. P51 opener Vs the P38? 3. Why just 5 ft of Duct Tape? 4. 3 Germ-X wipes? Seems a strange number.
There probably isn't a real answer to these questions besides "Just what I settled on", but perhaps not. I'm just curious.
#1038367
02/27/16 08:32 AM
Posts: 117,050 |
1. Why a bic lighter instead of one of the Peanut XL lighters from County Comm? They will hold a lot of easily obtained conventional zippo lighter fluid plus they seal up with O rings and shouldn't leak out any of the fluid. 2. P51 opener Vs the P38? 3. Why just 5 ft of Duct Tape? 4. 3 Germ-X wipes? Seems a strange number, maybe just because we are (Normally) used to dealing in pairs or even numbers not odd.
#1038372
02/27/16 09:05 AM
Posts: 117,050 |
Patty said that I need to go the big gun and knife show here next weekend. WOOHOO, I might go seeing as how we just got our tax refund!
#1038375
02/27/16 09:25 AM
Posts: 117,050 |
Hey Guys, I just had an AH HA event.
It dawned on me that IF you want to carry a Kit like Gary talks about you could find a fantastic Clandestine bag in the form of a small Bible Case! You can find them in sizes just about what Gary recommended and they usually have some sort of religious symbol/words on them and would be great for carrying a kit. I might have to see what is available locally.
#1038378
02/27/16 12:50 PM
Posts: 4,889 |
Randy, I've had mixed results from peanut lighters. Bic is a trusted brand but still has to be tested (they don't always work).
P51 is larger and easier to use.
This kit has to be SMALL so less tape. I've chaired more but it takes space and weighs a lot.
1 wipe per day for 72 hours.
Remember this is suppose to fit in your pocket.
#1038381
02/27/16 03:06 PM
Posts: 117,050 |
OK, makes sense.
1. I was just thinking the Bic might become activated in the bag in some way and leak out all the butane. BUT you can always wrap a rubber band under the "Safety Lever" to keep it from being pressed down. 2. Duct tape (If you get the wide roll) can be torn in half or smaller and create a lot of taping power. 3. I also like the P51 Vs the P38, it is yes, easier to use. 4. I was thinking the wipes were more for disinfecting than just cleaning.
AND you reminded me again that it is supposed to be a POCKET kit. I keep trying to prepare for everything. Doh!
#1038545
03/02/16 06:41 AM
Posts: 117,050 |
Grey Ghost Gear has a Slim-line admin pouch that looks nice. Here are the dimensions.
Measurements:
5" Tall 5.75" Wide 2.5" Deep
Nice looking pouch and I think it wouldn't be to much bigger than Gary's max size, and it's a clam-shell type pouch.
#1038546
03/02/16 06:50 AM
Posts: 117,050 |
Gary, what do you recommend, a full clam-shell type pouch or a top loader, and do you prefer a horizontal or Vertical pouch?
#1038547
03/02/16 06:59 AM
Posts: 117,050 |
I am seriously leaning toward this one, just want to make sure I won't be hindering myself by not getting a clam-shell pouch. http://www.maxpedition.com/store/pc/5-x-7-x-2-Horizontal-GP-Pouch-Low-Profile-116p767.htmActually though it probably wouldn't matter. This will not be a Rapid access type of equipment. Maybe this one would be about the best size wise.
#1038576
03/04/16 09:08 AM
Posts: 117,050 |
Spent most of the night checking out pouches for a small large pocket PSK. I think I have settled on a 6x4x2 or a 5.5 by 3.75 by 2.5 inch pouch. Still unsure which one I actually want.
#1038793
03/14/16 09:39 PM
Posts: 117,050 |
My Problem is I try to figure out every contingency and prepare for it. These Kits aren't designed for that so I need Guidance and that is just what I am getting from this and your new revised thread. Plus there are a FEW things I could add on my own.
