 Re: Outdoor power solution -- The sun
 #568674
01/06/13 05:59 AM
coyotebc
Posts: 10,860  |
I noticed that JJ stated in this thread that he used the steripen
  Howdy Randy
The stripes of a tiger don't wash away.
Be a man of steel not clay
JYD #102
[Re: coyotebc]
 #568675
01/06/13 05:21 PM
right now I am looking at getting a UV sterilizer before camping season starts. How do you guys like the ones that you have  I like it. Easy and fast. Just remember, if the water tastes dirty, the pen won't fix that. Just makes it safe assuming there are no pollutants in the water.
 #568676
01/06/13 09:09 PM
coyotebc
Posts: 10,860  |
Thanks JJ Right now I use a combination of a mechanical filter and either boiling or chemical treatment Most people that are on well water in my area use a combination of mechanical filtration and UV sterilizers.
  I have been doing some research and the steri-pen has numerous good reviews
  I have heard of a few other manufacturers of UV sterilizers but I don't know anyone that has used them.
JYD #102
[Re: coyotebc]
 #568677
01/06/13 09:35 PM
I've read some reviews about the Steripen malfunctioning, but I haven't had any issues in the few years I've been using mine.
 #568678
01/06/13 11:00 PM
 #568679
01/07/13 12:12 AM
kuanomar
Posts: 1,918  |
I've used the steri-pen for several years on multiple trips into the mountains.  It has always worked for me.
  Things to consider with the steri-pen.
  Get a bottle with a wide enough mouth.
  Carry an extra set of batteries
  Some sort of pre-filter is a good idea. I found one that screws onto nalgene bottles, but even one of those small, metal coffee filters would take particulate matter out.
  The way it works is it scrambles the genetic material of the bad "bugs" with UV light.  This prevents them from being able to reproduce.  But, chemicals are not removed.
  If you use a hydration bladder (like camelbak) you will have to obtain, treat, then transfer the water into the bladder.
  The LED model doubles as a last ditch flashlight.  (Which I've used on several occasions)
  In my experience, they are effective, light and durable.
JYD#116
[Re: kuanomar]
 #568680
01/15/13 03:47 AM
tedsterosa
Posts: 1,037  |
can you post more pics of the parachutemandu?  I've never seen that variation.
JYD #181
 #568681
01/15/13 04:02 AM
WinterWolf
Posts: 1,138  |
i was looking at the Goal Zero 19010 Guide 10 Plus a while back, but it is a bit more expensive than the powerfilms. looks like i'll have to do a comparison at some point. i do know it has variable amperage capabilities though.
JYD #180
[Re: tedsterosa]
 #568682
01/15/13 04:25 PM
can you post more pics of the parachutemandu?  I've never seen that variation.  Here you go.  ![[Linked Image from i1008.photobucket.com]](http://i1008.photobucket.com/albums/af208/mediaperture/G21.jpg) ![[Linked Image from i1008.photobucket.com]](http://i1008.photobucket.com/albums/af208/mediaperture/PMDSheath5.jpg) Can't help but post this bad boy while knife pics are in the mix. The Scrapyard Regulator Bayonet! ![[Linked Image from i1008.photobucket.com]](http://i1008.photobucket.com/albums/af208/mediaperture/SY-Bayonet-8.jpg)
 #568683
01/15/13 04:34 PM
WinterWolf
Posts: 1,138  |
JYD #180
 #568684
01/21/13 05:28 AM
tedsterosa
Posts: 1,037  |
can you post more pics of the parachutemandu?  I've never seen that variation.  Here you go.  ![[Linked Image from i1008.photobucket.com]](http://i1008.photobucket.com/albums/af208/mediaperture/G21.jpg) ![[Linked Image from i1008.photobucket.com]](http://i1008.photobucket.com/albums/af208/mediaperture/PMDSheath5.jpg) Can't help but post this bad boy while knife pics are in the mix. The Scrapyard Regulator Bayonet!   DUDE!!! DUDE!!! <img src="/ubbthreads/images/graemlins/shocked.gif" alt="" /> Thank you for posting these pictures.  I did not realize that existed.  It is so awesome!!!  When did that come out?  It looks so good.  Wow, I can't get over it.  DUUUUUUUUUUUUUUUDDDDDDDEEEE!!!!!!!!!!!!!!!  And I really like the Regulator Bayonet!!! Great job on that.  I'll have to check out the thread of that build again. And the sheath looks good too.
JYD #181
[Re: tedsterosa]
 #568685
01/21/13 07:03 PM
greaser
Posts: 7,098  |
I sure don't miss lugging those sapi plates around although just a plate carrier is much better then the whole vest. Awesome pics.
JYD#176 "dein Gott schickte mich zu zerstören" "Sic semper evello mortem Tyrannis" "Sometimes the chance of a zombie outbreak is the only reason I need to make many of my life's Decisions." General Delivery
