Re: Outdoor power solution -- The sun
[Re: greaser]
#568686
01/21/13 09:13 PM
We have to wear side SAPI now. ;(
#568687
01/21/13 10:59 PM
greaser
Posts: 7,098 |
Ick what does the kit weigh now?
JYD#176 "dein Gott schickte mich zu zerstören" "Sic semper evello mortem Tyrannis" "Sometimes the chance of a zombie outbreak is the only reason I need to make many of my life's Decisions." General Delivery
[Re: greaser]
#568688
01/22/13 12:49 AM
Our IMTV (Improved Modula Tactical Vest) weighs about 35 lbs with front, back and side SAPI plates. A bit more with ESAPIs, but I don't know the weight.
#568689
01/22/13 02:02 AM
greaser
Posts: 7,098 |
But hey if its saving lifes its a good thing.
[Re: greaser]
#568690
03/17/13 04:05 AM
imaginefj
Posts: 3,141 |
Just ordered the Duracell battery charger with USB...
Now for some solar panels.
Join the NRA
JYD #69 If a 6 turned out to be 9
Join the NRA
[Re: imaginefj]
#568691
03/17/13 04:12 AM
imaginefj
Posts: 3,141 |
Can't find the panels anywhere cheap.
Join the NRA
Join the NRA
[Re: imaginefj]
#568692
03/17/13 05:53 AM
The cheapest I have found them is on Amazon. The prices there fluctuate white a bit. I have seen them for as much as $200 and as cheap as $90. So, keep your eye on the prices and it will change.
#568693
03/17/13 06:20 PM
imaginefj
Posts: 3,141 |
I'll keep looking. If the 10w was available for 90 I'd order it today.
Or I could get the goal 10 Adventure Plus Kit for under 100 and maybe be set?
Join the NRA
Join the NRA
[Re: imaginefj]
#568694
03/17/13 08:02 PM
The Goal 10 kit performs better in direct sunlight. A buddy has one and loves it. The biggest difference is the way either operates. The Goal Zero panels don't perform well in shade, overcast or dim light, but out perform the Powerfilms in bright light.
#568695
03/17/13 09:34 PM
imaginefj
Posts: 3,141 |
Hmm, maybe both are in order then? Chain the two?
I can get the goal zero for about half msrp right now.
Join the NRA
Join the NRA
[Re: imaginefj]
#568696
03/18/13 02:27 AM
The cells on a Goal Zero are not parallel, so chaining them with a parallel Powerfilm would probably not work. The paallel design is what lets the Powerfilm work in low light. That and the type of cells. One for good weather and one for inclement weather isn't a bad idea though.
#568697
03/18/13 02:46 AM
imaginefj
Posts: 3,141 |
What about making a circuit so you could run them both into the same battery or CLA. Then you would kind of have the best of both worlds?
Join the NRA
Join the NRA
